- Oct 29, 2012
- 1,392
I didn't have any luck at all, grinding or sanding UHMW. It only made surface finish worse and hardly removed any material. Makes sense as that's exactly what UHMW is designed to do. If you've got a scrap piece to experiment with, do give it a shot; maybe I just wasn't using the right abrasive.Everything I read prior to working with UHMW plastic is that abrasives will not produce a good finish. That said, I do have some scrap pieces, and I do have sandpaper from 180 grit to 3000 grit, it can't hurt to give it a try
