After you make the facing cut, run a dial indicator from the outside edge to the center and see if it stays zeroed. Then you will know if the cross slide is the cause, or other factors at play. If it traces the cut perfectly, proceed across center to the other side and see if it still traces with zero TIR. If it stays zero on the front, and moves on the far side, then you have a problem with cross slide squareness.
