The project is to machine a backing plate for a South Bend 9. I purchased a semi finished plate. The plate blank fits cleanly on the spindle and I started to finish the edge. All that happened was a lot of noise and some sparks. There may have been a thin cloud of very small black dust.
A quick review indicated the plate is likely cast iron. (I was not expecting that when I ordered the blank). Is there anything practical I can to with this plate? It appears to be very hard. HSS bits barely touch it. Carbide makes high pitched sound but it definitely does not machine.
I am comfortable machining a steel plate. I do not believe I have the skill to cut internal threads. Is there a source for semi finished steel back plates?
(BTW: It took the better part of 2 days but I was able to get a really stuck back plate off the lathe. It took repeated doses of penetrating fluid followed by heat on the plate and medium blows. That almost made up for the cast iron fiasco).
