- Apr 23, 2018
- 6,873
You don't necessarily need to use a horizontal cutter for the flats. You can make a facing cut with an end mill. Then you could, without moving the part from the milling attachment vise, rotate the vise around to do the plunge cut as wa5cab describes.
You probably don't have to worry much about indexing for this part. If you can hold it firm, you can machine it. At the end of the day, the AK will fire whether you make your mark or miss it by a mile. The photo of your part examples and the wide margin of tolerances proves my point. If you get the features positioned within 0.010" of where they "should" be, you're probably way ahead of the factory in Izhevsk, which has been fueled on vodka for 60 years.
