I've noted on a good number of videos I've observed that often minimal to no lubricant is used on mild steel and aluminum and in general for small operations/pieces. I was turning brass today on a 1228, between 1"-.8" at .030" DOC and 120 rpm. I like to paint on a little lubricant with a small brush because it appears it makes a difference and what I use has some staying power.
The cutting oil is from Harbor Freight at $10 a can and I grab a few during 25 and 30% off sales. I spray a little in a small container (thick foam) and mix near an equal amount of WD-40 in which cuts the viscosity down to light wt motor oil level. The chips were short and sticky as usual in this circumstance but the moment I sprayed a little 40 on the dowel thinning the mix even more, immediately springs started forming as seen in the picture. That in my observation suggest the WD-40 improved the cutting ease, am I correct?
I'm going to make it a habit to use lube a bit more abundantly on fine operations as my experience so far has suggested it definitely lengthens the lifespan of the bits and maintains uniformity of cut, especially if mid to high rpm is involved no matter what the diameter is.
Overall I'm very happy with my progress and confidence of hitting desired marks without redundant attention bordering on paranoia. Taking measurements with the mic is like a competitive sport for me.
