Lost my bearings.........
No shields or seals and no stampings on any of the bearings. NOS as in HD?
I'll search my parts catalogue and see if I can come up with HD numbers
Thanks for responding!
Are the bearings still pressed into the cases? I ask because they may have been replaced at least once, and whoever did them last, didn't flip them marked side out, like they should have? Also, don't shy away from bearings with rubber seals, if that's all you can find; just pick the seals out.
Yes and no. Inners still pressed in (and these are needles) Outers removed. Will not shy away from the rubber seal versions.
Didn' think of that...........thanks
That changes things a lot, the bearing numbers you were given earlier were for ball bearings and not needle bearings. Your dimensions are on the narrow side for a needle bearing, can you post a picture of it?
For needle bearings, there are different types as well, you can get drawn cup or machined rings, a picture of what you have can help identify which you have.
Needle bearing on the inner case......................ball bearing on the outer case.
Needle bearings no problemo to find
Pictures tomorrow
Thanks
