- Feb 24, 2018
- 1,044
over the last 10-12 years, I‘ve lost about 6 air compressor pressure switches. They last roughly about 2 years, then one of the contacts burns off, then I have a dead air compressor. I lost one last night, and finally decided to correct the pressure switch issue. I finally assembled enough parts to install a contactor rated for 4 times the amp draw of the motor, I picked up 2 cabinets (customer was sending them to the scrap dumpster) and work graciously donated all of the pieces and parts necessary to finish up the installation.
The air compressor runs perfectly, the pressure switch now only carries the load of the contactor coil, and hopefully will last a little longer, I have a new pressure switch on order, the one being used now has one burnt contact and one functional one, the functional one will hopefully last until the new one gets here.
