Yeah, it may be overkill, but if you have the space, and it's in good order, you won't be disappointed.
My ten cents Jesse, its the case when the opportunity knocks or you may be searching a long time. I am a bigger is better guy, and for that price
we will expect wear somewhere because whoever bought the mill new, was not just to look at it, it was to put it to work. Myself old school, I
live with wear or worn out things even my shoes, my back, worn bones, machine backlash and all the worn things in life. Myself I wouldnt be
afraid as long as nothing is broken. So you may be machining small parts today but it may change in the future I mean a little outside work for it.
At least you will have a mill, that I suppose you could trade up or down if need be. Like a lathe they all have wear in the middle where they get
used a lot, so you just work around the fact. Like the old timers running totally worn out machines, backlash measured with a yard stick, but they
machined perfect parts...
sam
sam
I tend to agree with this. My bridgeport needed shims. But I intended to learn to scrap before I got it so I did not care one bit. With shims in it it does get tight right at the end of the travel, but if I need it, I can still use it. I will tell ya right now, even shimmed up, I have more travel in every direction, more versatility, and just as tight as a china machine. And for the cost of a smaller import at that. I was a bit worried at first. But after some months using it, I would not change a dang thing.
That being said, you could get a small import and do al you want to do now.
What really sold me on the BP over the import.... I can sale this BP in 30yrs, likely for what I payed for it. And still be able to get parts for it in that same 30
Now if I could find an old iron lathe
Too bad, but at least you found it out before you pulled it off the truck
