- Mar 26, 2018
- 2,725
OK, I've dabbled in scraping a bit and have watched more hours of video on the subject than I care to admit, but the seemingly high barrier to entry (in terms of tooling) has kept me from getting serious about trying to learn. The small amount of scraping I have done has been rather successful in terms of accuracy, but terribly slow. I am currently using a file with the front ground into a scraping blade.
What I do have:
So I started looking at scrapers. I see two options easily accessible to me: Sandvik scrapers through MSC and Anderson tubular scrapers. Both are about $100. OK, a lot of money for a metal stick but it will last a lifetime so I can deal with it. I have heard mixed thoughts about both due to their relative stiffness. I have also seen some shop made scraper plans floating around, although I can't remember where. If it takes me more than a few days to make the scraper myself, I'd rather just buy one. With work and family and other shop projects, I don't have the time I want to spend on it. I've checked eBay, but scrapers there are few and far between with prices almost that of a new one.
Next up, my file scrapers dull fast, and while HSS would be way better, I do see the draw to carbide scraper blades. First off, holy moly, $50 a blade on eBay sure seems like a ripoff, but maybe that's how much they run. Again, if it gets me going, the price is fine. But now you need to be able to sharpen carbide. Don't think a green wheel will cut it so now I have to find or build a slow speed lapping disc. Again not an impossible task but the cost and barrier to entry grows.
Any tips? What is a good scraper to start with. Are the prices I'm seeing just market value? Anyone have a used one they want to part with? Do you need a separate tool for flaking? I would imagine a Biax would be absolutely overkill for a hobby guy unless an eBay steal came my way.
So next to marking compounds. Hi Spot Blue seems to work OK, but it goes on very heavy and within an hour it is dry and barely transferring at all. Great for later stages of scraping but not at the beginning when you actually want to see your blue. What works better?
What other measuring tooling is needed? I've seen those scraping flats (steel disc that bridges across your high points) but don't know what they are called or where to find them.
Any tips on learning resources. At this point in time, I have neither the money nor time to attend a scraping class, but I'm all for video instruction. Have no issue biting it off and trying to learn more myself. This is all a hobby, but I do identify it as a useful skill to know.
What I do have:
- 18x24" surface plate, grade B
- Dial test indicators, 0.0005" and 0.0001"
- Dial indicators (0.0005" and 0.0001"
- Dykem Hi Spot Blue
- Several files ground for scraping
- Crappy bench grinder with coarse wheels
