The original motor on a TH54 should have been a 56 frame rated at anywhere between 1700 and 1800 RPM (motor nameplate ratings have changed over the decades without any actual changes in the motors). I have to agree that I would avoid a VFD drive system that was rated up to 3600 RPM. You would be better off with one that uses a nominal 1800 RPM motor.
Okay so for now the vfd is off the table. I'm
Looking for a direct bolt in. That being said. The motor I have is an atlas super power motor. I just assumed it was original because it's atlas. It never fit correctly however. So I'm looking for a 56 frame and if the rpm says anywhere from 1700-1800 I should be alright?
Regards-Carlo
