I also saw some norton blue wheels. Anybody using those?.
I'm finding this thread to be very informative. Some more good links for the different wheels would be great.
i have a 5 hp 3 phase 16" magnetic rotary table surface grinder , manufactured by Pieco .
i have a blue wheel on the unit now.
i use this machine primarily for resharpening hardened meat grinder extrusion plates,
but it can flatten any ferrous metal from 1/8" thick to 16" thick and up to 16" in diameter.
the surface grinder has an 8" diameter cup type grinding wheel that is 4" deep .
it's a coolant fed beast , having a table that is electromagnetic and counter rotates to the direction of the grinding wheel .
the magnetic rotating table turns at 100 rpm, the grinding wheel turns at 1725 prm.
the machine was built in the 70's and gets used 2 days a week, a good old workhorse.
very accurate
the blue wheels give a fine finish, but have a tendency to load up moderately quickly.
i have used the pink wheels with great success as a side note.
grey wheels cut nicely, but seem to leave a coarser finish.
