- Aug 26, 2013
- 1,061
A PDF of the drawing file is attached.
Excellent work!
I agree the less runout the better and made at home is often far better than bought, I was aluding to to fact that some people worry about 0.0001" runout and I have never personally seen a new cutter that was pefect.I've seen good arbors cut a piece of metal that was only .002" out on one corner.
A quality arbor will give better results consistently. Your saw blades will last longer also.
You can make a good arbor on a lathe. I would use O1 tool steel.
Thanks Emilio.Also, take a look at the design for the Robb Jack AB series saw arbors. They are the cream of the crop.
Robb jack also sells the cap as a replacement for $87 if you want to start there. These are heat treated, ground and finished.
Saws: Marindale Electric Co.
Ebay: Malco, Cleveland, Thurston, Niagara. I bought these on Ebay also for $10 each new.
