The headstock is not high, the tailstock is low. All depends on how you look at it. The tailstock is easily made taller by placing shims between the upper and lower portions. You can scrape in the headstock if it is not level, which makes sense (if you are skilled at scraping and diagnosing lathes), and you can also scrape the tailstock to make it level and pointing in the correct direction. Been there, done that, needed to shim it up after getting the geometry correct. There is no magic height dimension stated for the headstock beyond "13" swing."
