Im setting up my new lathe and working through bed leveling and headstock/tailstock alignment. I have a MT5 ground test bar that reads with no movement/runout at the headstock. At 11.5" down the bar it reads with .0003 showing a slight bias toward the rear of the lathe. I moved on and aligned the tailstock between centers with a straight ground test bar. I then mounted a Bison 4 jaw direct mount D1-4 chuck and put a 3" aluminum round stock 14" long in and turned a barbell. I am getting a taper of about .0025 over 9" smaller at the headstock and larger at the tailstock.
Now for the question.
Am I better off adjusting the headstock or adjusting the feet on the lathe? or both? or is this as close as I will get it? My Starrett 98 shows the bed to be level front to back. Im hoping someone familiar with the lathe can give me some pointers before i loosen the headstock bolts.
Thanks, Jeff
Thanks, Jeff
