- Jul 8, 2018
- 880
Not sure why people have such problems with the fine-adjust-at-top style. Just keep it locked down tight if you don't use it, and it won't bother you. One in awhile, it's pretty handy for ensuring the (plunger) indicator tip is properly perpendicular to the work. Not even sure when fine-adjust-at-base would even be used, unless you are zeroing the needle by position instead of just rotating the dial.
Anyways, like everyone else said: get a Noga, perhaps more than one. They make a huge difference. It's the arms that make the difference, not the actual base, but if you look for the arms as parts they're basically the cost of an entire unit.
