Looking at a cnc lathe with a c axis and live milling capabilities
Yes much less material. How to attach the the hold down tab without welding?
A light press to slip fit. Once assembled into the tailhousing it can't come apart or even move around.
Here is a better picture of the 7/8 bore of the tube showing the fit of the tab.
I like the idea.
The fit needs to be leak proof.
JB Weld, or #2 Permatex maybe. Or some other sticky stuff that is not silicone.
Would the tab hold with just the two narrow sides pressed in?
The top of the tab is open.
Oh crap, I see now. That tab does not hold the sleeve in place, the tab holds the speedometer gear in place. :faint: Maybe a 9 axis horizontal machining center is in your future :grin: I need to think about this a bit more.
What holds the sleeve in place?
If I were going to machine that in one piece, I would start with 3'' round bar and machine all of the round parts in the lathe. I would not screw around with trying to do offset turning.
Do all of the 1.125 surfaces in one setup, flip it over and drill & bore as needed. Then over to the mill and machine the tab.
It's held in by a single 10x24 bolt and epoxy to seal it up. Yes the tab holds the round speedometer housing and the driven gear in.
The 1-1/4" x 2" x 4" blocks I get for around $8 each in lots of 50. I checked on 3" round 4" long and they are $22 each.
9 axis huh, I can't even envision how that would work, much less fit it in my shop.
