- Oct 16, 2019
- 6,852
Hey all, as many of you know, I week or so ago I bought a new-to-me Long Chang LC-30A mill drill.
I bought it from the second owner who bought it from a local machine shop. The fellow I bought it from only used it as a drill press.
It didn't come with any tooling unless the factory drawbar counts. It has an MT3 spindle which I know is not the norm for mills but it will do for my needs at this point.
Over all it's in good condition, just really grimy and covered in crud. In disassembling it to get it out of my truck I think that there is still some of the original cosmoline on the column. Nasty stuff.
My plan is to pull it apart, clean and inspect everything and then reassemble. It will likely get paint as there was a lot of bondo-type filler that was dislodged when I pulled the column off the base.
I need to fashion a gantry crane so I can move the thing around my shop. Getting it off the truck in pieces was one thing, lifting pieces onto my bench is something altogether different.
PIctures to follow
PIctures to follow
