The screw holding the cross slide leadscrew block/nut to the cross slide seems to work loose easily on my Logan. So that could be #3 on your list.Logan Lathes commonly have cross slide back lash for two reasons.
Good point. Fortunately that's "usually" easy to fix with some Locktite.The screw holding the cross slide leadscrew block/nut to the cross slide seems to work loose easily on my Logan. So that could be #3 on your list.
