- Oct 24, 2024
- 5
This past weekend I finished assembling my 1943 Logan model 200 and started it up! It came here in pieces. My expectations were low so some growling and chatter from the headstock didn’t cause panic but I had to find out why. I decided to open up the headstock and make a list. I didn’t get very far. The main spindle has 2 Woodruff key half moon slots. One slot and key under the bull gear and the second under the spindle gear. Both keys are in a straight line.
The bull gear has a key slot and a plunger. Turn the bull gear so that plunger is at the top. Your bull gear key will be at the top also. By following disassembly instructions both keys are at TDC. ALL STOP.
If I rotate the spindle and place the plunger TDC! this should place the woodruff key at the spindle gear end of the shaft to TDC also. My spindle gear key slot is at 230 degrees as you face the chuck. It appears the bull gear has sheared the key. The gear and shaft found new homes. The really bad news is I can’t press the shaft out, yet. It must be a real mess in there.
