- Apr 6, 2011
- 2,082
I was trying to lower the shaper table for the first time today and made a little discovery. It's broken. I'm trying to figure out the best way to go about repairing it so I thought I'd troll around for some ideas.
The problem:
The table is raised/lowered on a threaded shaft. On this QC shaper that shaft is two pieces. There is an inner rod that is attached to the gear and turns. There is a threaded "tube" that the turning shaft is surrounded by. The threaded "tube" is held on to the shaft by a single set screw. The set screw is threaded on to the "tube" and a small "dowel" on the inside end engages a hole on the inner shaft. Over the year the threads in the "tube" part are getting pretty beat up and loose. The bigger problem though is that it looks as if someone tried to raise/lower the table without the shaft and tube being held together. This wallowed out the hole in the shaft as well as made a huge, deep gash for about 1 1/2" down the length of the shaft.
I did a quick drawing to try and give a better idea of what it looks like:
Without the two being held together the inner shaft spins and the threaded tube remains stationary. It don't go up and down!
Any thoughts or questions?
Thanks,
-Ron
The problem:
Thanks,
-Ron
