Making the dial. I won't describe the actual machining..just standard stuff. I had to figure out how to make the graduations....100 in all.
First was to make an index wheel. Using Viso mechanical design I made a index wheel with 100 graduations, every 3.6deg apart. I color coded the graduations. Red for the 10s, green for the 5s and black for the thous. Printed in in hi res on glossy photo paper and mounted it to a thin aluminum disc with double sided tape. Fortunately for once I thought ahead a bit and before I set up to machine the actual dial I installed a collet in my spindle and snugged it up with the draw bar. Now I could remove the draw bar and use it to lock the index to the back of the head stock spindle. To make the graduations I decided to engrave them. Installed the headstock and milling column from my Unimat lathe onto the cross slide of the 618, centered it and locked it down by tightening a gib screw on the cross slide.
I don't have a way to lock the atlas chuck from rotation. I used sort of a prony brake with a piece of webbing, fixed to the bed, wrapped around the chuck with about a three pound mass on the free end, and always turning the chuck backwards to index.
Graduations were down in three passes / rotations. First for the 10s cut in to about 1/2" set the carriage stop and did the remainder, then moved into about .3" for the 5s, and finally the thous.
All is good so far. By the time I was done...well I was just glad to be done. Tore the set up all down, and then said "damn" I forgot to mill flats under the 10s so I could use numeric marking punches to mark the major graduations. Ended up trying to punch them on the round and didn't do so good on some.. so not going to show that....embarrassed.
Index set up
Unimat mounted on cross slide for engraving
At the zero mark I used a thumb screw to lock the dial to the shaft. It is drilled all the way through with a #36 drill bit and then the dial is reversed and a #25 drill is drill back to just inside the collar below the locking screw, so that an intermediate piece of brass is installed to do the locking on the shaft to prevent galling.
To make it more readable for my ol eyes I put nail polish in the 10s and 5s graduations.
Finals here
David
View attachment 67134 View attachment 67135 View attachment 67136 View attachment 67137
