Sorry, I've been traveling and just noticed the question. The manual crank for the head on the G0762 is definitely an inconvenience (I use other words in the shop ;-). Especially since unlike a full sized mill, the crank is on the left of the column in the rear, not in front on the knee, and you've got to lean over your bench to get at it. I've got an old motor I may repurpose someday as an automatic cranker.
On a bridgeport or full size mill, I agree with Tim that you would usually only use the quill for drilling/boring. On a bench top mill, though, there is no dial on the Z axis
except on the quill, so you're forced to use the quill while milling (unless you have a DRO in Z). Basically, when milling I try to minimize the quill extension: crank the head down until the cutter is almost touching, then use the dial on the quill to touch off (or touch a feeler gauge/cigarette paper), then zero the dial on the quill and keep extending the quill until you're at depth. For anything but very light cuts I have to use the quill lock to ensure the depth doesn't creep up.
Overall, I'm quite happy with the mill, but in addition to the manual crank in the back, other annoyances include:
- max spindle speed of about 2500 RPM,
- no spindle lock (need two wrenches to tighten the drawbar),
- "inconvenient" to tram in the nod axis (shims),
- the levers on the gib locks are too long and interfere with way travel in both X and Y (had to grind them shorter),
- the gib locking knobs are made of some soft pot metal (I've already stripped the one to lock the Y axis),
- and the zero locking knob on the Y axis interferes with way travel (I just removed it since I use a DRO).
- surprisingly few good places to mount holders for lighting
