- Dec 3, 2013
- 1,849
Both machines have PMDX-126 breakout boards with PMDX-107 spindle control add-on boards. The PMDX-126 is powered by 110vac or 220vac and has 12 vdc on the board to power the proximity sensors. Otherwise you could use a separate power supply for the sensors.Thanks for the info!
for my research what breakout board are you using ? since parallel voltage is 5.5v at best and these take 10v at minimum I'm assuming either you're using something more advanced than I used previously or there's another board inline with the switches.
Not sure what your looking at for motion control. My mill uses an Ethernet Smooth Stepper motion controller which mounts directly to the PMDX-126 and the router uses a UC100 USB motion controller. The UC100 works okay but will occasionally loose connection which is really frustrating. Eventually I will replace the UC100 with another Smooth Stepper.
