Lifting Heavy Lathe Chucks
I am looking at the same capability. I certainly can't lift a 248 lb 18 inch chuck myself. I have looked at the Skyhook and for a price tag of almost $1k, I decided to look at other alternatives. I found, but have not purchase yet another option. Its an pick-up truck crane with hand winch. This will give me better reach and lift. The version I am looking at can bolt to the floor toward the rear of the lathe and still have the reach to remove and install a chuck. It can also spin 360 degrees. For $289, I think I am going that route.
Here's my (slightly modified) Harbor Freight truck bed crane.
It came with a hand pumped hydraulic cylinder, rated at 1000 lbs (I lifted my 700 lb. Kalamazoo saw and left it hanging overnight) and costs less than $120. Make your own post and you're in business.
This one comes with a winch
If that was really the first time he tried it, it would have been wise to put a piece of plywood under it!
Sky hook is just too much money.
I'm pondering something as these chucks are becoming more difficult all the time.
I heartily reccomend the skyhook, I have one that fits my Aloris CA tool holder block, and also made a few aluminum bases that can be used on other Tee slotted machine tables. That said, I put up a barn door track in the overhead over the lathe and mill and used a couple of HF winches that I found at a garage sale, they work well.
Also, I drill and tap all my chucks (short of the little ones on my 9" lathe) for eye bolts for lifting purposes.
Not only do I use my SkyHook on my 13" TurnPro, but I use it on my Bridgeport Clone too. My rotary table and super spacer weight more than my chucks. I made an adapter that clamps the SkyHook to my mill table. The rotary table and super spacer are very easy to install and remove, Easy peezy ;)
