Here you go Mal. I was in the shop and took a couple of pics. The hook is and easy build. About 3/4” round bar for clamping in the jaws and 1/2”x1/2” square coming off at 30 degrees....welded and bent. Here’s a couple of pics. I can turn the chuck either way once it’s supported by a hook of the come-along or winch. Going from horizontal to vertical...It’s easy.
just make sure the jaws are tight before you flip it...because when removing a jaw from the lathe, the jaws don’t have to be super tight. But when flipped.... Jaws better be tight or it’s going fall out of hook.
