The flatness of the roof beam angles make for quite weak strength against whatever is supported at the middle of them. Like said above, I would not try to lift more than 100 pounds as is, and would watch it carefully for signs of problems. Like also said above, vertical braces like 4x6's close in to what you are lifting, can lift very heavy amounts. It is useful to create basically a gantry crane as narrow as what you are lifting, with the existing structure just helping to keep it all vertical. The setup can be cobbled together, just be aware of the forces trying to spring the lumber in compression and avoiding the entire cobbled setup racking into a parallelogram under load. It would not be crazy to lift at least a ton with such a setup, depending on understanding the load paths and accounting for them.
