- Oct 29, 2012
- 1,387
Doing some spring cleaning in the shop I came across this chain hoist I forgot I had. Then I remembered I have a beam clamp somewhere, found it. I hung the chain hoist from the center beam of my shop.
I haven't lifted anything with it yet; I can't decide whether this is a bad idea or not. The shop is 30'×30' so this beam is a 30ft span and supports the entire middle of the roof. It seems quite substantial but I don't know how to calculate what's a safe weight to put on it. Whoever designed the building did that math and I assume the weight they designed it for is the weight of the roof, nothing else. But there must be some safety factor, right? How much would you say is OK to hang from the ceiling? Is anyone here lifting from the ceiling like this? If so, how much?
