- May 16, 2016
- 1,704
Thank you for your response and have you thought about a vfd which would give you the ability to extend the rpm range. It could be quite extensive and add some torque with the right motor that would enable you to use the vfd functions to its capacity.
They are light machines but put together well. Take a look at the spindle wall, spindle and tailstock thickness, the consistent look of the castings and has a good reputation for user feel with positive engagements and disengagements which to me is almost like riding a motorcycle. It should stir the soul, It's not just about the specs.
Yes I have thought about VFD, and it is the obvious sensible solution to many things, I even have 3 ph on site. It just doesn't have soul, well that's the way I thought about. I would have to fit a 3 Ph motor but I don't think that would be very hard. Liang Dei even have a 2hp 3ph motor that's a bolt on fit, I could have ordered it that way, I just didn't think I'd need it. Obviously didn't think it out enough. I know it's crazy, here's me always telling people go bigger go better, and I broke my own rule. I need to find out more about VFD, will they work with any 3ph motor, how much increase and reduction in RPM can you get without damaging the motor, is there a loss of power, there must be a trade off some where?
