I received the leveling feet. Can someone explain how they work? I know a dumb question but I have never used this type and I don't want to screw up the mounting proper. Does the mill rest on just a nut? If so I would need two more nuts. The other used to lock the one of the sides.?
Also, is there a reason to connect the front and rear mounts with a couple crossmembers (welding)? I've seen a lot of bases with just the front and rear members.
