The problem on a worn machine with adusting the gibs, as you have stated in your initial post, is that the wear is not even. You can adjust, shim, or whatever you want to on the end of the table and it will still be loose in the middle by the amount of wear on the table. I have not scraped in a machine myself, but I have taken Richards scraping class and have ammassed most of the equipment I need to scrape one and have plans to scrape a couple of my machines. The problem with scraping a machine in from my viewpoint is the aquisition of all the things you will need to do it. Straightedges run about $10 an inch, and to scrape a 42" table, you need a wedge straightedge (which are harder to find than a flat one) to do it. So that's $400+ for a single straightedge. You can make a hand scraper yourself, but that's more time. A Biax power scraper will run you about $700, new blades are about $100 each. Richards scraping class was $600 when I took it, some years ago. You need a surface plate large enough to check a 42"+ straightedge on so figure on a 36" x 48" surface plate. Depending on where you buy it and what grade, that's about $500. So my take is, unless you have a one of a kind machine or you really want to learn how to rebuild machinery, use it as is if it's doing what you need it to do, otherwise buy a better machine then sell the one with the wear.
