- Mar 19, 2014
- 2,682
It’s not easy, maybe impossible to true a bench grinding wheel using any kind of dressing devise with your hands and no tracking support. The typical vibrations of a bench grinder and the uncontrollable movements of your hand will all telegraph into the wheel being dressed. Also, some dressing devises will follow the contour rather than cut is own path leaving a clean wheel but still not round and true. A diamond is the best and then it needs a good support that tracks uniformly across the stone/wheel. Even a simple guide block holding the diamond with a step that hangs on the outer edge of the tool rest and moved manually is better than just your hand(s)…Good Luck.
