Jobber are regular length, ordinary drill bits. S&D are generally considered larger than 1/2", but with 1/2" straight shank (it may be they are any reduced shank drill bit).
I suggest you get a 1/16 - 1/2", "middle of the road" HSS set of bits (don't get the real cheap ones, but expensive bits are easy to damage - go for the middle). Your favorite tool supplier will have some that will be fine. Only get cobalt or carbide for specific tasks. Drilling is pretty rough / crude (extremely useful) activity. Drill bits get consumed, for all sorts of reasons. You'll get used to sharpening, grinding to a different point (i.e. for flat bottom holes), burning the corners off, cutting the shank short, cutting the entire bit short - after a few years you'll end up with hundreds of drill bits (I have a lot that other people have thrown away - cut the chipped & burnt end off, repoint, clean up the shank - away you go).
