Let there be LIGHT !
joebiplane
Nov 22, 2010
364
My aging eyes require a lot of light... I would like to find an inexpensive , yet , Classy way to put some lighting around the spindle of my new Griz-Mill. I recently saw an article on a forum ( which I have misplaced), about a circular bulb surrounding the spindle. It may have been too complicated for me to attempt. but are there other ideas that some have used ??? I like projects, but I won't alter my brand new Mill without getting a Great result Attached is my present solution, a magnetic trouble light stuck to the area behind the spindle. It works but i would like a lot of Brite white light
others have made similar lights to Daves using LED's, some by modifiying LED camping lights and others by buying the seperate LED's.
If you do a search on LED Mill Light or similar you will probably find something.
regards
bollie7
I'm working on th ecamping light on E-Bay as I type... Will tyhe quill go through the hole? we'll see
Joe
