- Oct 17, 2018
- 944
This is a question for those of you that have worked in a machine shop environment: when drilling holes in a part, do you lock down the vise, or do you let it float? I learned to let it float, but another instructor makes the students lock it down for each hole. We had a lesson where the students needed to drill 8 holes (1/4" to 1/2" diameter in 1/4" thick aluminum) and they had to relocate the vise for each hole (we have nuts and threaded studs). It took them about 90 minutes. They center-punched each hole, then had to locate the center bit over the punch and drill. For the larger holes, they had to center drill, 1/4" drill, 3/8" drill, 1/2" drill, then go to the next hole. It was very frustrating for most of them.
I think the instructor was concerned about safety, but I've never had a vise with a part in it spin in a drill press. RPM was about 800.
For larger diameter holes or holes where the location matters, I use a mill with the X-Y table, but the students are not there yet. I can see locking the vise down for production work where you are drilling the same hole in the same part in the same location many, many times. For this part, I would have punched the holes, center-drilled them (letting the vise find the center), used the 1/4" bit on all of them, used the 3/8" bit then the 1/2" bit on the larger holes.
I'd like your thoughts and comments, thanks!
