- Dec 18, 2019
- 7,321
On the HSS tool grinding thread, I posted about making a tool that could cut a small retaining groove to hold down some LED rings I picked up on AliExpress. I am in need of better lighting for my drill press. I ground two tools to make this, a parting like tool and a grooving tool.
As I'm about to cut metal, I thought I'd better make a better drawing of what I was going to do. Looking at it, some of the dimensions make me uncomfortable. To cut to the quick, I've got 0.050" from the groove to the bore. (Assuming I can hold dimensions to the drawing.) Is this a reasonable amount of material? Material is 3.75" diameter 6061, 1/2" thick. I'll reduce the thickness to reduce the weight. I was hoping to epoxy magnets to the back after counterboring.
I just have the top view of the drawing. (Haven't sat down to draw the side view.) The dotted lines represent the groove that is subsurface. I haven't put in the locations for the magnets. Is 50 thousandths enough? It's not holding anything but the weight of the plastic LED rings. Thought I'd ask. I don't have any other stock in that large a diameter to try, so it would be nice to get it right the first time.
