- Mar 21, 2018
- 1,718
Try cutting a 64 TPI thread with a piece of 1/32 rod and you can see the problem. The thread becomes a spiral "U" shaped groove around the screw rather than a "V" shaped thread. In most cases, I grind threading tools from HSS. Carbide is a fair, general, turning tool. But if I'm doing threads, I need more "right" than mass produced carbide can provide. At least in my price range. There may be finer tips at a higher cost. . . I don't know. It's a lot easier to just grind it.
Although they probably exist, I haven't seen a carbide insert for a thread with a greater TPI than 44 TPI, so at 64 TPI, you're going to have to use HSS. I use HSS for materials that carbide just can't handle - like threading plastic. I can get my HSS bits much sharper than any carbide bit that I have seen.
