I posted last week asking about thread cutting tooling and appreciate the feedback you guys gave. I have the benefit of having access to a lifelong machinist who works for a friend of mine. He and I have become friends over the handful of visits he has made to my shop to help me begin to understand a little bit of what I can do here with the machinery I've got. Yesterday, he helped me out with cutting outside threads and showed me in very meticulous detail the exact process he uses. He brought a piece of scrap aluminum round bar because it's more forgiving of a hamfisted novice like me when I might crash my tool into the work! I found a random nut that turned out to be a 1" - 8 and he walked me through the process of turning the bar down to the right diameter and then how to set up and cut threads. This was our finished product and the fit was nice just like the two pieces were made for one another (which, funny enough, I guess they were!).
Tonight I decided to do it myself with a 3/4' - 16 nut. While I'm generally happy with how it turned out, I think I got just a few thou too small on turning the bar down and ended up with play between the nut and threaded bar. It's not enough to pull the nut off, but there is that probably 2-4 thou of play. It does thread on as it should otherwise, but my takeaway is to be more diligent and detailed on my measurements. I have never done a lot of precision measuring in my life so learning to properly use and read a caliper and micrometer has been a learning process. I look forward to the day it is second nature as I'm sure it is to most of you. Anyway, here is my finished product from tonight.
