Lathing question.....
Firstgear
H-M Lifetime Diamond Member
Dec 7, 2018
653
If I have a 7/8” diameter, 36” long bar and I need to turn down about 10” or so to 3/4”, is the best thing to do is face one end and put a center drill into it and then use my live center to support it and machine it down? Or do I also need to line up the spider on the bar prior to facing off the one end? Operation steps?
Face , center drill and turn . If you need to , turn it in 2 set-ups if you get chatter . ( turning 5" at at each set-up )
Edit . Not knowing what size lathe you have , you may need that spider for rear support . Watch your rpms and check out the " Bar whip thread " .
When do I cut it off the 36” length?
Ah ..............you could cut it to length first and face and c drill both ends , then use a center in your 3 jaw and live center in the tailstock . Use a drive dog . Flip it and repeat .
Or turn the 10 inches to diameter and cut it off the bar .
26” overhanging the back side seems like a lot......
Drive dog?
Look up at #2 post !
A lathe dog . Drive dog . Clamp it on your shaft and drive it with the chuck .
Ok....I have a PM1440GS......
I don't know PM machines , 14 x 40 ?
Why can't you just cut the bar first to maybe 11"s , chuck it and turn it ? Then saw it or part it off to 10" .
Bar whip.....after watching the video in that posting, not be something I soon forget! I need to get that band saw sooner than later!
