Tim, as I recall, you have a Logan 10x24, right? Nice lathe but a little light and I suspect your top speed is probably less than 1800 rpm. I also recall you will mostly be turning smaller work pieces. Given these conditions - light lathe, low speeds, small work pieces - carbide is not going to be the best tooling choice for you, either brazed or inserted carbide. Yes, it will cut but you are far better off learning to grind and use HSS on that lathe and for your intended purpose.
Another option, especially if you have an aversion to grinding tools for some reason, are the HSS inserted tools from AR Warner. Works just like carbide tools, with similar inserts and geometry. I own them, I like them and they will work well on your lathe and for your purposes. However, a good HSS tool will still outperform them.
My advice is to learn to grind HSS tools. They are the tools your lathe was intended to be used with.
