- Mar 12, 2013
- 302
![2013041595133657.jpg 2013041595133657.jpg](https://www.hobby-machinist.com/data/attachments/17/17185-f5f8090a48f426d9f8e57efd6f2ac49a.jpg)
To see if your tool bit is in center with your work take a pocket ruler and place it between your tool bit and the work then move the cross slide in to contact the ruler . If the top of the ruler is tipped toward the back of the lathe the bit is set too high and if it is tipped toward the front the bit is set too low. If it is centered the ruler will be straight up and down. Great time saver.
