My dial has no numbers but lines at noon and six o'clock. I've found on odd thread these are the only places I can engage. On even threads It seems like I can engage anywhere, even between divisions and still the roots/threads line up. I have not officially made any threads yet. I mean non that looked nice or worked. Used a pen to mark and this is what I have come up with so far. Have not tried this with metric yet.Thread chasing dial engagement rules for English pitch threads. Even # threads you can engage half-nut on any line. Odd # threads you can engage on any numbered line . Half pitch threads use number 1 or 3 line.
Sent from my LG-D850 using Tapatalk
Thanks guys for the reply's. I think I have it figured out now. I did the test Tom suggested and determined I cut a 28 pitch. I now I knew what numbers the gears were and figured out where they were placed. I've included a pic of my change gears.
From what I can tell The large gear on the bottom is E and is coupled with C which is hidden.
The next gear up is D and is coupled with the B gear. Gear A is driven by B. The gear next to A must not be changed which would make sense as the small gear above has no adjustments. Does this sound correct?
No manual Mike. Thanks for the explanation though.
