- Mar 26, 2018
- 2,725
I just had to bore and re-thread a lathe chuck back plate (2.25"x8). To get the part on size, I measured my spindle over wires, machined a gage from brass (aluminum is fine too) as close to the spindle measurements as I could get, and used this to check the fit as I was working to make sure the backplate would fit the spindle. It is tedious, but it allows you to nail the size right on. Also good threading practice.
Alternatively, if your chuck is a camlock, remove the whole chuck (part still in the jaws), test fit the part, and then reinstall the chuck in the same holes it came from (mark them!). One downside is that test fitting the part will be tricky with the chuck hanging from the back!
