- Jan 31, 2016
- 12,871
I am cheating and uncaring so I program the taper out of the part.
What do you do?
Yesssss.......they were the days !
What do you do?
First thing I would do is take your rpm's up by at least 1000 , then move your tailstock away from you .003 . Recut till you achieve what is acceptable to you on this piece . After this piece , grab a lathe mandrel or something hardened and ground , put it between a turned center in your chuck and a dead center in your tailstock and indicate the bar true . Turning at 175 rpm on a 3/8 shaft is slow motion , crank it up ( especially if you're using carbide) . I'd start at your machines max rpm and work down if necessary .
I tried carbide at higher speeds,lower speeds,then went to HSS,and tried different speeds. 175 was my last cut. If it turns out to be wear in the ways,do I shim the tail stock?
What do you do?
What do you do?
Maybe misaligned, even probably. A cheating, uncaring machinist would set up the work piece, then run an indicator along the 3.5"', then adjust the tailstock until the two ends give the same reading. THen try a cut and see what happens. Of course that's not really aligning then tailstock for general use, but might work pretty well for a one-off.
What indicates that this is more likely a tailstock rather than headstock (or both) alignment issue?
