- May 23, 2014
- 100
Hello All,
I have some questions to try and figure out where I stand on this lathe. I'm new to lathes. This is my first and over the last few days I've gotten it set up and takes lots of cuts. I'm having some issues I'd like some advise on. I've taken the lathe (SB 9c) apart, cleaned, painted, rewicked, oiled and leveled as well as i possibly could. I read through "how to run a lathe" and many other publications with good info. Not to mention the endless hours of youtube.
I have a scrap piece of solid bar stock 2.25" long x 2.25" diameter in a three jaw chuck. The type of steel is not known. It's magnetic, soft enough for a file to cut it, has no signs of rust and no matter what I do I get a mate finish. I don't know if that will give any clues to the type of metal or not. Anyways. I'm having trouble with depth of cut, feed rate and belt slipping. I'm using an adjustable link type belt from harbor freight. The tool bit is a HSS bit I ground. After a few try's it came out pretty good. I've also tried a carbide tipped bit and a cheap insert tool. All with the same results. I have the gears set up to give me a .0031 feed rate and the belt is on the far right pulleys, 235rpm. All is well if I keep my depth of cut below .008" but anything more then that and the lathe bogs down or the belt jumps off.
I have nothing to compare this performance to so I'm asking, is this typical? I feel like I should be able to take more of a cut. I'm going to try a different material but this piece of scrap is not dulling my tool and seems to be soft enough to machine. It's been in a lathe before based on the marks I see on it. I know it's hard to say with so many variables but, with a slow feed rate and an easily machined steel how deep should I be able to cut on this SB9c?
I apologize this was so long but I wanted to give as much info as possible.
Thanks in advance.
Thanks in advance.
