- Feb 13, 2017
- 2,138
I would put the cabinet on the floor and then a 12"x2" u channel upside down under the lathe itself. This will do double duty of raising it and fixing the lack of stiffness of the cabinet.
Being rather tall, 6'3" when I can stand up straight, I faced a similar problem when I acquired a Craftsman 12X36. I had a stand built from steel, formed a chip pan, and then raised the machine with a 6X6X1/4 box tube. The 6X6 tubing provides much of the rigidity for the stand. That put the machine at a good working height and left plenty of clearance for the threading gear train. The tool boxes reside on a shelf about 6" off the floor. I had built a base for a Grizzly 9X19 on a stand that raised the stand some 6" above the floor. A square of angles the size of the stand and 3" dia legs with adjusters on the bottom.
In both cases, the frames were first shimmed up with wooden wedges to get rough dimensions. My shop is a residential grade wood structure that is prone to movement over time. So they get checked and adjusted every few months.
