If your having problems tightening leveling bolts many times when I level a lathe I need to re-tap the leveling bolt holes as they get burrs on them. I have also seen people forget to loosen the jam lock nut. There is a trick on bigger lathes to lift them. This only works on the bigger machine with a center pedestal. Jack up the tail stock end so you can slide in a hard wood (oak) 2" x 4" board under the middle pedestal and let the jack down. This will allow the head-stock end to teeter up. You may need to move the tail-stock and saddle down to that end so it raises up, being the head-stock end is heavier. I use this method a lot as it is safer then jacking the machine up super high. Lathes are so top heavy and can tip over so easy. Good luck. Rich
