JT Maybe Im getting the wrong impression from your post. You sound like you need to pour concrete to set your lathe on. Unless your shop is a dirt floor, I would just use leveling feet, or if the machine is a bench top model, build a sturdy bench , and add leveling feet to it. You must be carefull bolting the machine to the floor, as you could induce twist if not correctly done. Do you really see a need to bolt it down?
