I cannot figure out how to quote while using my phone but the comment about tool height was the answer.
Tonight I took extra care in checking my tool height, it was a little low so I centered it on the work piece using the method where you pinch a machinist rule between the tool and the part. I then took a surface cut to make sure my stock was concentric, mounted a dial indicator on the bed, measuring the tool post, zeroed everything and proceeded to take .040 cuts, three cuts, measured after each cut, and each time and my stock measured where it should be.
I had no idea being off center would cause that.
Thank you very much
