On overall accuracy, I clock mine to the machine dials over several inches to see if the scales track with the dials with each revolution, if looking at shorter accuracy I use wither 123 or 246 blocks with a 0.0001" indicator. My magnetic scale on the tailstock was spot on after 4+" of travel on the "0".
For the cross-feed, the dial should tell you what you need to know. For checking the carriage travel, zero the indicator against the face of the chuck and zero the DRO. Then move the carriage back and place the 1-2-3 block with the 2 in. face against the chuck and bring the carriage up until the the indicator reads zero against the 1-2-3. The DRO should read 3.000.
