My suggestion for anyone wanting to learn how to sharpen HSS tool bits is simple: Just jump in with both feet and start doing it!
Try different grinds until you get the tool to cut/perform the way you want. If it doesn't work, just do some more experimenting. You've got nothing to lose and a lot to gain. There definitely is a feeling of satisfaction grinding your own bits and drills. Before you know it, anyone can get to the point where you will just start eye balling things and it will become quicker and quicker to touch bits up.
Another thing to play with is where your tool is on center. I like to run mine just a little bit above center (except for threading, tapers, etc. where the bit needs to be right on center), but YMMV and you'll have to experiment with your individual tool and lathe.
Have fun!
Ted
